Triathlon activity : Not possible to change to T2, only stop it.
The triathlon activity is not working as expected. After swim and change to T2 (via Lap button) everything works fine. After biking I pressed again the Lap button to change to T2, but i don't worked, nothing happened. But the clock was not frozen, stopping worked fine. It is reproducible.
Please fix it.
  • I don't have this problem and it works as expected. After the swim I press Lap and it changes to T1. After T1 it changes to Bike as expected. After the bike I press Lap and it changes to T2, then I press Lap again and the run leg starts. I press Lap again and the triathlon ends and lets me save it.
    I'm on SW 10.10.
  • I have the same version, there is some issue with the bike profile if you changed it, I did a reset for bike and triathlon and now it is working. I will play around to see which setting is wrong.
