I feel there are touchscreen functions that are either missing or broken
For example: previous run widget. You can scroll to the glance, tap to select, and it will bring up the widget. But the only way to see details for a run is to press start. And then to see more details is press start again
Why can I not tap to advance? Why do I need to press start? Even the side menu that comes up when you press start allows you to scroll and select with a tap. There is no point in using the touchscreen for navigation if I have to constantly switch between using touch and using buttons
Are other Garmin watches the same way with touchscreen navigation? Why is tap not universal for "select"?
