Selecting 2 connectiq datafields almost always results in crash
The 955 seems to be able to add only 2 connectiq datafields, however even this doesn't work when I select an ANT(+) field or anything remotely complex as one of the two...
For example adding one of the following:
ANT+ Heart Rate Monitor: https://apps.garmin.com/en-US/apps/7c83d402-4b68-4f0a-b167-7139788a19b3
Auxiliary Heart Rate v2: https://apps.garmin.com/en-US/apps/a461bc0d-828d-47c8-a4a5-8d014b5fedc9
DCR7c0: https://apps.garmin.com/en-US/apps/360a26c4-e2bb-45b7-8f97-2694ccf74eef
Stryd Power zone: https://apps.garmin.com/en-US/apps/18fb2cf0-1a4b-430d-ad66-988c847421f4
But also:
All in one: https://apps.garmin.com/en-US/apps/6dec42e9-7fee-402b-95a4-a111e83d45e3
Dozen Run: https://apps.garmin.com/en-US/apps/9ff75afa-d594-4311-89f7-f92ca02118ad
Cause issues (on their own they work fine, but can't add any 2nd datafields afterwards). It almost always ends up in a crash (IQ! error). First adding a normal one (battery field) and then adding an ANT enabled/complex one also causes a crash.
Adding two simple ones seems to be ok.
Can anyone confirm?
  • This won't be very helpful, but the 945 LTE has a similar issue so you're not alone :/. I've seen this issue with Stryd Zones combined with pretty much any other CIQ data field.
    I try to work around it when it happens by changing the order I add fields, *and* trying to exit the activity ASAP so that the data field config changes are saved before the field crashes. (If the field crashes at this point, it'll be auto-removed from the activity.) Even with the workaround, sometimes it takes several tries before I can successfully add both fields.
  • Thanks for the feedback and maybe workaround... Sucks to here it's also there for the 945 LTE. Still have my FR945 as well, will give it a try on that one too...
    I usually only connect my HR strap, though I did use my stryd on the 945 a bit as well and can't remember it causing issues. Ugh...
    Hopefully garmin will look into this quickly.
    *edit*
    Just tried it with the 945 and doesn't seem to happen there, could add ANT external HR field and stryd zone field withouth issues.
