Finished a triathlon and activity won’t upload to connect app, even after doing another activity which uploads successfully very frustrating. I just wanna compare my data to last years race
Try a manual upload to Garmin Connect Web - How Do I Manually Upload an Activity I Recorded to Garmin Connect?
If you get any message other than Import Complete, then there is a problem with the file. In that case, please attach it to this thread. We can take a look to see if it is repairable.
Will try this when home currently in the car with no PC access
here is the file zip I would greatly appreciate if you could fix it
This will work - 2023-05-28-09-38-13-fixed.zip
Fixed using Fit File Repair Tool
Some suggestions to help minimize the occurrence of corrupt fit files:
seilogramp I think I might have a corrupt fit file, are you able to fix it for me please? It is a swim file from my Garmin Fenix 7 sapphire.
8495085, I can try. but you'll need to post the fit file in question.
2023-07-01-10-00-38.fit.zip mine won't work either. too bad as I won the local race.
thanks! this also did the trick 'time fixer' www.fitfiletools.com/
