Edit run distance in Garmin Coach exercise
Hello guys, I did my second run with coach Greg (in the treadmill) but the recorded distance is not accurate. How can I edit the distance in the app? It doesn't seem to have an option to edit.
  • Note that if you edit the lap distances or total distance it will have no affect on the training program. The coach will use what is reported from the watch to adapt your program.
    In what way can't you edit the distance? View the activity, click Edit Activity, click Distance and write the new value, Save.
    Didn't you get the option to Calibrate and Save when the workout ended? I haven't done any workouts on the treadmill so it might work differently from a standard run.
    You can't edit the different lap distances in Garmin Connect. Only the total distance.
  • Apple and Android are a little different interface, but I think both should have a vertical triple dot button, select that and click edit activity, scroll down until you see the distance, click the Distance to adjust it.   Click DONE... and then SAVE
