Forerunner 945 corrupt running activity
Hi,
I went for a run this morning and after finishing the run it would not sync to Garmin connect. Not over wifi, not directly with the phone and also not with Garmin express. When I tried to upload the fit file from the watch manually to Garmin connect also this failed so my .fit File is corrupt. I just for testing purposes started another running and cycling activity and both sync normally.
Why is my file corrupt and any ideas of how I can fix the corrupt file? I already tried fitfiletools.com but the corrupt time fixer did not help.
Any hints/tips are appreciated.
D1FD3547.fit.zip
  • I used a combination of 2 repair tools. Starting with FitFileTools using the section remover, then running that "repaired" file through Fit File Repair Tool
    This will work - BbbB-fixed.zip
    Noted that you used the HRM-Pro which I suspect was the cause of the issue. HRM-Pro, Tri, and Swim will sometimes corrupt activity fit files
    Otherwise, here are some suggestions to help minimize the occurrence of corrupt fit files:
    +Former Member
  • Hey guys,
    Thank you very much for your feedback. I have actually been using the "Download HR" Feature after most runs because I assumed the option is there because some data is not transmitted during the activity. Won't be doing that anymore.
    I'll go through all of your tips. I always keep the strap and watch up to date but I have never removed recorded actitives.
    thanks again
    bb
