Drill log function normally allows to enter the distance once the Drill is complete. This is particularly useful if you want to track activity when drilling sculls with one hand or using pool toys like kickboard, etc. This function works when using Pool Swim feature.
However, if you create a Workout in Garmin Connet and such workout contains Drills segments (even though you indicate a segment length) - there is no option to enter the segment distance while workouting. Simply when you press a loop button to finish a Drill, worgout jumps into the next segment without givin a chance to enter the covered distance. And as a result - some segments lengthes are left not recorded and the total distance of the workout became less than actual.
Dear experts, any ideas?
