Hello,
since a few years I‘m using the Forerunner 945 which normally works well.
But there is a problem with swimming.
Lately, I used the Forerunner on 25 meter lane in an indoor swimming pool and the lanes were counted correctly (even with a not very correct turn).
Motivated by this, I took the watch to my preferred outdoor pool with a lane of 50 meters which causes the following problem: Approx. in the middle of the lane the watch counts 1 lane which leads to a count of approx. 2 lanes per lane (I set the pool size the 50 meters of course). I tested this in another pool with a lane length of 50 meters. Same behaviour.
I did some resets of the watch. The whole watch as well as only the swimming settings. I also tried both arms.
Swimming style is freestyle. Not the very best technique but also not the worst.
For testing purposes I took my Apple watch 7 in to the same pool. The lanes were counted correctly.
Now I‘m a bit helpless. I would be very happy if the Garmin watch could count the lanes correctly (don‘t want to use the Apple watch as a sport watch because the Garmin is much more advanced for sports).
I really couldn‘t understand why the watch counts 2 lanes without a change in the movement. Just technically it couldn‘t be that hard to recognize a movement on one axis and get the change of the movement in the opposite direction on the same axis.
Would be very happy for some tips.
Thanks in advance.
Greetings,
plate
