Hi,
I've noticed today that I'm having problems with the GPS accuracy on my watch. This morning when setting up my activity I noticed that the map on my watch showed my start location as approximately 200 metres or more away from my actual start location. I did eventually get it to show the correct starting position by turning it off and on again. However, when I checked again later the GPS was showing the same as in the morning with my start position actually 200 metres plus from my actual start position and this time I've not been able to get it to correct itself by turning the watch off and on. Is anyone else having this problem? And does anyone know of a solution to this?
Other than turning it off and on I've tried:
- changing the GPS settings for the activity
- syncing to Connect
Thanks
Jonathan
