Is there a way to view weather, temperature, and sunrise/sunset during an activity? For example, with Suunto you have Suuntoplus. When you activate the weather feature, you can see these things while running or walking. Thanks
Yes, there is such way for temperature, and sunrise/sunset. Just add custom Data screen / field for the chosen activity as described in manual.
To see weather during activity (I suppose you mean data from…
You can use the widgets during an activity. Add a hotkey for watchface.
I've disabled the lap button so if I'm not doing a workout I can go back to watchface and look at the widgets. To go back to the…
Very well! I was not aware of such possibility. Thanks!
I have assigned the hotkey to long press of the back button, so the lap button functionality (short press) is preserved.
To see weather during activity (I suppose you mean data from weather forecast), it is not possible directly, but there might be a custom application on Connect IQ Store (app type "Data field") - however I have not found such one.
