Forerunner 945 has been showing VO2 after all walking sessions sessions.
After having gone for a Run on the weekend and setting it back to Walk, there is no VO2 results.
Please advise, any help would be appreciated?
Thanks
Terry
Thanks
Terry
I have used my watch for many walking activities and it has never recorded a vo2max. I wasn't aware that it would, until recently from a post from Garmin or FirstBeat about how the algorytim works and ranking of how it uses the different activity types.
I believe if it has recorded a vo2max for running, it won't use the walk calculation for awhile iirc. Which makes sense as running will give a much better representation of what someone's maximum oxygen intake is per body weight as it is a higher effort activity, closer to your vo2max effort. Even while running it won't give a vo2max reading update for me unless my HR is above zone1 Heart rate it seems most of the time. Which also makes sense, if it is too easy it can't accurately extrapolate what my high end fitness level is. Same for a walk that would also be typically a low intensity effort for most people.
Here is an interesting article from Garmin explaining some eof it, but not maybe all of it. I am looking for the forum post about it.
https://support.garmin.com/en-US/?faq=lWqSVlq3w76z5WoihLy5f8
https://support.garmin.com/en-US/?faq=HVMcrDvQ3m2xEFh1aVMbU8 (HAS NOTES ABOUT NOT TRUMPING A PREVIOUS GOOD READING with subsequent "OK" readings... )
quoteing site:
The type of activity you complete can determine if you will receive an updated VO2 max estimate. Your overall VO2 max estimate is taken based on the following four activity types, listed in order of preference based on their accuracy. The most accurate VO2 max estimate will display in Garmin Connect and will overwrite less accurate methods for 30 days. Not all Garmin products support all methods of VO2 max estimation.
NOTE: If you complete a qualifying cycling activity with a power meter, a separate Cycling VO2 max will populate. The Cycling VO2 max will update each time you meet the Cycling VO2 max estimate criteria.
This activity type yields the most accurate overall VO2 max estimate and will trump all other activity types.
Example: You record a Run activity with GPS, which generates a VO2 max estimate. This VO2 max estimate will display in Garmin Connect and will only update over the next 30 days if you record additional Run activities with GPS. Other activity types below in this list will only update the overall VO2 max estimate when the most recent Run activity with GPS is older than 30 days.
Example: You record a Walk activity with GPS, which generates a VO2 max estimate. The next day, you record a Run activity with GPS, which generates a VO2 max estimate. The overall VO2 max estimate in Garmin Connect will be updated regardless of the age of the Walk activity because Running activity with GPS is #1 in this list.
This applies to walking done during daily routine without recording an activity.
Check you max heart rate. To get a VO2 max value you need to reach at least 70% of you max heart rate for at least 10 minutes.
Your run might have increased the max heart rate.
What NickMN posted is also very interesting and could cause it. The run VO2 max will stay there for 30 days. After that a walk can update the VO2 max.
