About gps
Hi , im looking for a garmin watch with extremely accurate (insta-pace) i train for short distances so i want to check my speed changes , i heard that 3 models has the best gps accuracy fr 745 the best followed by fr 945/245 , for the 945 experts here what do you think about gps accuracy and especially insta-pace compared to other garmins ,thank you
PS im talking about the fr945 NON LTE ( price diff)
Top Replies
All Replies
  • FR10/15 is the best for instant pace
  • im looking for a garmin watch with extremely accurate (insta-pace)
    I don't think such thing exists.
    0 Former Member in reply to jmto
    yes its true but some devices are more accurate than others , im looking for the best available option
  • GPS insta pace accuracy is a tautology. Seriously, GPS is accurate to only within about 5 meters, so one data point can be 5m behind you, the next 5m out to the side, and the next 5 m in front. While the algorithms can work out your most likely path and distance (and therefore average pace), real time pace from GPS is very difficult.
    The best available option for insta pace is to use a STRYD.
    All the devices you mention use the same GPS chipset, so there isn't much difference. Local conditions (eg. tree cover, buildings, narrow valleys, etc) are going to have a much bigger effect on accuracy than the specific model.
  • None of the modern GPS watches get pace from GPS only. Pretty much all watches fuse the data from GPS, accelerometer, and gyroscope to provide a more stable and accurate pace. That is called sensor fusing. But not all companies are equally good at algorithms. I'd say my experience with Suunto FusedSpeed was pretty positive. Coros also has something they call intelligent stride model. They claim they use machine learning to improve pace accuracy individually for each user. I can't say the same about Garmin's instant pace. Garmin still appears to fuse the data, but based on my experience with F6X does that quite poorly.
  • For accurate instant pace, it's best not to rely on GPS. A well calibrated foot pod or Stryd will help you much better in that department. In case you are training and racing on a track, the Track run app does a remarkable job for instant pace once the track is calibrated. Having said that, when you train and race on a track, it's probably just as easy to simply check the stopwatch every 100 m (assuming that you know how many seconds per 100m your target pace is.
    0 Former Member in reply to eberends
    ty that helps
    0 Former Member in reply to silentvoyager
    thxxx
    0 Former Member in reply to mcalista
    ty i will consider the STRYD
    i already returned my fenix 6 pro for that matter , still waiting for the fenix 7 to come out
