I wonder whether is any option or perhaps also an useful IQ-App avoiding wrong recordings of the total number steps and floors using the hiking mode in conjunction with trekking poles with my FR945.
When using the standard app for hiking (and the same holds for the mountaineering app) in conjunction with hiking poles, generally recordings for the total number of steps as well as for covered height differences in terms of the number of floors are not correct. It seems that acceleration from moving arms, which is quite different, when using hiking poles is responsible for this kind of error. In order to show correct values of the the total number of steps covered as well as of the total number of floors covered, the corresponding algorithms seems necessary to be changed a bit.
When comparing after-tour values, e.g. for distance covered throughout the day with the total number steps, it turns out that distance is correct, whereas the number of steps by far are not. Calculating step range from the distance covered, when hiking poles have been used always leads to unrealistic step ranges between 1 and 2m.
In order to avoid this kind of trouble and inaccuracy, I'd propose to calculate number of steps with the extra information from distance covered and with the individual step size of the user (which had to be defined in advance for this purpose). Perhaps it might also be helpful to define a special app for trekking-pole hiking and/or mountaineering. What do you think??
