New Garmin giving problem with battery
Moved to Forerunner 945 forum
What version are you on? (Settings->System->About)
Try updating to latest version, make a hard reboot; hold power button (upper left) until it shuts down, then start again with power button.
Make sure you are not using "All Day" setting for Pulse Oximeter sensor. Just to be sure, remove any CIQ watch faces to rule them out as well.
Good luck.
(Also, take a look at this post: https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-945/268203/reduced-battery-life)
The big power drains are:
So check your settings for all of these.
Also, after any update (and often the watch needs an update when you first receive it), it is a good idea to power down the watch, and power it up again. This can often reduce battery drain.
