Hi,
Yesterday I bought the Forerunner 945. The main reasons;
1) I often run in fields / forests. Previously i used the Vivoactive 3 and I experienced inconsistent pace (-> Too slow) when running in a forest or in a field under trees.
Which was very frustrating. When you know from experience you're running for example at a pace of 5:30 and it only shows 6:30 or even slower. It makes you run faster which is still not representing the actual pace and increases your heart rate unnecessarily.
2) have a more precise heart rate reading.
Regarding 1) Does anyone know which GPS combination i should use on my forerunner 945 when running through forest and field ? I would like to have the best setting to receive a correct pace reading when running and also have the most accurate GPS accuracy.
Is this GPS + GLONASS or GPS + GALILEO?
Note that I'm running in BELGIUM. I assume that the location of your country makes a difference which GPS combo is the best to use on my 945.
Currently, i have it on GPS + GALILEO. just because Galileo is a European system and Belgium is located in Europe. But i have no clue that's the best setting / option for what i'm trying to achieve.
Thanks a lot for the help.
