Howto delete alarm (already deleted on Garmin Connect) ?
Hello,
at every new firmware I hope to be able to either disable or delete alarms on my watch.
Now under 7.20 I would like to keep my 6:59 am on weekdays but erase all others (I have some more on almost each days).
I tried to disable them in Garmin Connect (android) but they all still "ring" (and of course I synced). I also tried to delete them : not more luck.
So : is there a way to delete / disable unwanted alarms on the watch (preferably without a full reset) ?
Thank you very much.
  • For me it works just like it always has worked since I bought the watch for over a year ago.
    Hold up button on watch, select Alarm clock, select the alarm you like to update and disable or delete it.
    If you edit the alarms in the app you must make sure you back out from the page so the changes are saved. On Android it says "Settings saved successfully". When it syncs your changes will be sent to the watch.
  • Thank you so much !!!
    I don't remember since when it didn't work anymore (but I tried quiete a lots of beta fw) and going into up, then alarm clock I got a really long list of disabled alarms.
    I am really happy with your answer, coming from the 920 on which we could only set alarm from Garmin Connect I didn't thought it would be possible on the watch.
