Hi!
Is it only me or are you also experiencing that the battery time has worsened significantly after the last update to version 7.10?
/E
Hi!
/E
I wouldn't say "significantly", but it does seem to drain maybe 15-20% faster for me than it did.
I'm not sure what else to try.
Maybe try to try less.
I have the feeling that sometimes we do not let the watch settle after an update, we test more or look at the battery stats 20 times per hour. For sure this causes battery drain.
Please compare the software version after one or two battery charge cycles.
Curious on the outcome.
Cheers
J
No
I have a question I get 1.05% battery drain an hour I always thought my battery was bad but I just realized I'm running 20km a day everyday so is that why my battery sucks? I didn't think to count runs. I have airplane mode on pulse OX off and don't use music feature and no apps installed.
For me similar to previous FW.
But I see battery influence of battery aging.
1,5 hours run beg.2020 - 3% (watch in normal mode)
1,5 hours run yesterday - 14% (watch in airplane mode)
Also during night battery drop out 5x more then before.
Time for 955:)
New sleep tracking require more battery since is calculated on device and not on Garmin cloud. Same happened when new sleep tracking was added to Fenix 6 - more battery drain overnight.
