Scratch on Bezel of Garmin Forerunner
Hi all,
I recently did a little gardening and ended up scratching the bezel of my forerunner. I understand that the bezel is plastic, is there any way to remove/reduce the scratch marks ?
Any advice will be helpful!
Top Replies
All Replies
  • I have not tried anything on watch face, but as far as wet sanding goes likely following a similar procedure for plastics/paint would work. Although to prevent issues I would start at the least grit step first... working way up as needed, then going back to the smoother grit steps.  I have used toothpaste and electric toothbrush in final steps of sanding, could be a decent first try.  I'm sure google has better ideas on this however.
    Highly recommend these 8$ protectors (3pack) from amazon!  Cant tell they are on!
    (3 Pack) Supershieldz for Garmin Forerunner 945 Tempered Glass Screen Protector, Anti Scratch, Bubble Free
  • I also got a scratch on my 945 watch face.  I am very dissapointed and would have purchased these covers if suggested by Garmin.
    I will try.
    Anyone successful rubbing out a scratch on the face?
    0 Former Member in reply to 1356621
    It's Garmin's fault?  If you dropped your cell phone and it broke, it's the manufacturer's fault for not suggesting a protective case?  Shame on your automotive manufacturer for not suggesting a windshield shade and now your dashboard is sun faded. Classic example of diverting blame from oneself.
