Anyone knows if you can create a training with running and push-ups?
If I use strength I can add run, but I guess the gps won’t work.
and if I use run, I can’t add strength as a segment?
These type of multisport activites are always tough to log, the few times i have done them I record it as a run, hit lap at strength workout part, then hit lap again when I start running. can pause at strength section. Then when done I create a stength activity for the amount of time in pause or time in those laps. I prefer the pause in the non-run portion, otherwise the acitivity total for the day will be double counted a bit.
Using a custom cardio workuot, you can create steps of 'jog' and then other steps like pushups, rest, etc. Not sure if GPS will be one though being that in the jog step it doesn't give an option for distance
