Hi, does disabling Pulse Oximeter affect other watch functionalities (for example: heat, height acclimations)?
If you mean altitude acclimatization then that's not true, it's not based on spo2 but simply on your time at the given altitude/elevation.
Ok, so I can turn off pulse oximeter and I don't have to worry that this will affect the operation of other functionalities. Generally, the PulseOX accuracy is so small that I do not expect that the data…
Correct heat and height acclimatation do not rely on pulse Ox.
Ok, so I can turn off pulse oximeter and I don't have to worry that this will affect the operation of other functionalities. Generally, the PulseOX accuracy is so small that I do not expect that the data from this sensor is needed for anything but display in widget.
