Any software to correct GPS track record?
As the GPS problem occurred today, anyone know any program can correct the offset of the gps record?
  • The error isn't constant, I did a run yesterday and starting point and end point was the same, but the track didn't end to the same point, but to a offset point was in another direction.
    So even if you calculated a fix for the locations it isn't easy as that. You would need manually to edit the whole track and know the route you took.
