Just had a run with my 945. GPS was way off during the run, I mean about 50-100 meters off reality during the whole route.
Has anyone else had this today? Using GPS+Glonass setting.
Janne / Finland
Janne / Finland
I have done a few more experiments and think I have worked out what is going on.
Before going for a run today I connected to GC on my PC and did a sync. I verified the CPE had downloaded correctly by checking…
Not impacting everyone, but it is a system-wide issue impacting multiple device types, not only Garmin devices.
I've just done some work today, and you can take the GPX file and make a manual adjustment to the lon / lat and correct it.
It would be too labour intensive, so I made a small python file to make the…
The problem (for me) and this workaround is that it assumes the entire run is offset by a consistent amount. That hasn't been my experience.
I'm probably just going to have to wait until the files are updated, knowing that the recent activities' map is inaccurate. This isn't a deal killer.
That’s a fair challenge - my offset was consistent through the run, so the solution worked. I do think it’s unlikely Garmin will update the files though...in my experience they treat data as empirical, therefore we should all still hope the fix comes through soon!
I actually just updated it with two spaces per indent, so correct.
In order to run it, you’ll need python downloaded onto your machine, the code in a script (called say, gpx.py) and in a folder with the file you want to adjust.
I found out the adjustment by looking at a previous run’s gpx file and calculating the offset from the first lat / lon records in files. These were then updated in gpx.py along with the input filename.
from a shell / DOS print, I then ran the script (python gpx.py), and hey presto, it created a file called “output.gpx” I could upload into Strava after I’d deleted the run in there.
Simpleish!
any idea why it'd be highlighting the letter "f" in "finally" and saying "syntax error"? Thanks for your help. This is all in the name of getting a PR after 47 attempts on a mountain climb...haha
If there is an error on line 1, then your computer (iOS / Linux) isn’t finding your Python executable. I was using Windows, with the python executable in my class path, but if you’re using e.g. Linux you need something like this.
https://askubuntu.com/questions/694031/why-does-python-in-linux-require-the-line-usr-bin-python
...try a python tutorial. I learnt it in two hours!
