Just had a run with my 945. GPS was way off during the run, I mean about 50-100 meters off reality during the whole route.
Has anyone else had this today? Using GPS+Glonass setting.
Janne / Finland
Janne / Finland
I have done a few more experiments and think I have worked out what is going on.
Before going for a run today I connected to GC on my PC and did a sync. I verified the CPE had downloaded correctly by checking…
Not impacting everyone, but it is a system-wide issue impacting multiple device types, not only Garmin devices.
I've just done some work today, and you can take the GPX file and make a manual adjustment to the lon / lat and correct it.
It would be too labour intensive, so I made a small python file to make the…
Unfortunately no improvement. The CPE file has been updated and is now "current". Then I did a 15s restart. Went outside and tested: correct position after approx. 2 minutes after he was 300m away again. Want to start a run later: after 2 minutes I gave up waiting for the GPS and I'm off. After about 5 minutes he started to recognize movement, unfortunately 500 m away from my correct position. After about 40 minutes of running he finally had the right position and that went well until the end of the run. So it doesn't really work out yet. At least my Stryd gives me the correct distance / pace.
The Sony chipset was the issue. 935 uses a different chipset, more which not only did not had the issue but is more precise (but uses more battery)
Levon For me it was CPE recent as well, started a test walk - still completely off.
Stopped and restarted watch. Waited a while after the GPS was found. Walk back was right on track then. so if anyone is still having problems, maybe a restart can help.
Hello this was posted to our support pages, but just wanted to add it here for transparency. The Activity GPS Track From My Garmin Watch Is Inaccurate.
Could you provide a short explanation what actually caused this?
