Watch wakes up at midnight and drains battery
So, I wanted to save battery and turned off the watch after completely charging it. It woke up itself in the middle of the night and discharged to 10%.
I tried all, including a complete reset. Stll the discharge at night.... It is running the latest firmware. Alarms are off. No apps and widgets, no music provider.
Any suggestions?
  • Just a bit off-topic, it is the WORST idea regarding battery health to turn any device with Li-Ion or Li-Poly batterys off after charging it to 100%. This will degrade your battery quickly
    But concerning your problem, this is clearly not normal. Does that happen while you wear the watch or did you put it aside?
    Have you already tried a full shut-down (not the deep stand-by if you just select the power-off option in the controls menu)?
  • Any suggestions
    Contact Garmin Support
