My FR945 recently started to exhibit some spontaneous high HR spikes, e.g. suddenly from 80 bpm to 180bpm for some seconds, then back to 80 bpm, sometimes more sometimes less but without any apparent reason.
I checked the internal built-in self test and maybe some of you with working watches which do not show any OHR problems could tell me your test results?
I have to admit that this is just a comparison test, without knowing what these values mean or what actually is tested, there is little insight except for that your test results are the same as mine.
My watch is SW 5.50
To run the test, do the following:
- wear your watch on your wrist
- turn off your watch until the screen goes blank
- press DOWN and keep it pressed. Press LIGHT and keep DOWN pressed until the Test screen appears
- You will see the main test screen with the small QR code on top
- press BACK several times until you see the OHR Test on top
- press UP and wait 5s
- press DOWN and wait 5s
- press START and wait 5s
My result is:
AGC: ------
LED Sample: 536907016
Heart Rate: 112 bpm
ILP Result: S2 Exceed Limits
LED Result: __
Stage 2 ILP Test Done
It would be interesting if anyone has another value for AGC or LED Result, same for ILP Result.
