After the update to version 5.50, my watch cannot connect to my old JBL Endurance Sprint headphones anymore. Tried connecting phones to the headphones, no problem. Any suggestions?
My HRM/Earbuds still connect after the 5.50 update. Have you gone under sensors and accessory, and tried to connect under the headphones themselves? It may also help to disconnect them and then reconnect. You could also make sure the headphones are not connected to anything else when you want to connect them to your 945. Let us know if any of these tips help and how it goes.
Did you try to remove the headphones from the sensor and add them again repeating the "initial pairing" procedure? In my case the problem with my Jbird Vista is that after updating to 5.50 the earbuds disconnect after 5 minutes. I am not able to solve this issue, that appeared for the first time with this firmware and the previous firmware.
Just did this and it worked! Thanks Mirko! I had tried reseting the watch, earphones to no avail. Let's see if this fixes it for good or I will run into the same disconnect issues :)
