Software Version 5.50 - Forerunner 945 - Live
Update can be downloaded through Garmin Express or Garmin Connect Mobile.
Clarification: For those of you who received 5.40 this update only includes the following:
Addressed an issue that caused VO2 Max update and Training Status to not update
If you have not yet received Version 5.40, then the update will include the above, as well as everything that was previously in 5.40 which I have included below.
- Fixed an issue that caused CIQ watch faces to display 0 calories.
- Added improvements to prevent dropped phone connection.
- Other minor improvements and bug fixes.
- Fix an iOS reconnection issue on some phones.
  • I want to simplify my latest question. I think the functions and features of Forerunner 945 for different language/nation is the same. Thats means the bug or fixed may be the same or almost same. However, for example. The version 5.00 update. The international version have 21 updates/fix/improvement. The APAC version only have 3 updates/fix/improvement. I can understand the APAC version a later time than international, but I can't accept the unfair !!
  • I truly don't understand why is there a need to differentiate (or maybe discriminate) between countries. Only reason should be just due to language or maps. But functionality wise, everyone should have the same experience. No? Languages and maps can be updated separately from watch functionality.
  • No problem with battery though. Garmin please fix the sleep. No sleep data for APAC since update 2 days ago.
    0 Former Member in reply to DPSK
    Same issue here, no sleep data after update for apac version
  • Today's suggestion is not smart enough.
    I just gotten the 5.50 so I wanted to test it by doing the activity.
    I discarded the activity without running.
    I tried to run -> workout -> today's suggestion, it says I have completed it. No way to redo the activity?
  • have a problem since update tot 5.5. In garmin connect app, when i tick on a activity i've done, to see specifick haertrate or avarage speed (all the small orange cirkel with grafic in it), the connect app closed itself and i see the homescreen of my iphone.
    It's only the activities i've done with firmware 5.5, the older ones, when i click on small orange cirkels everything is oke. iphone 12 pro max ios 14.3
  • I see similar in the Android app, eg if I select Training Status the app crashes & restarts.
  • I am the same as you, I have FR945 for 10 days and it never worked (immediately updated to 5.50), before with FR645M it worked
