Hi!
Im new to zwifting and found something "strange" but cool.
My setup: Kickr Core, Edge 830, FR945, HRM-Run (dissolving strap), Zwift on iPad.
My settings:
-Edge 830 in Indoor training mode, free riding, collecting data from Kickr and HRM via ANT+ (for Recovery etc on the Garmin Connect Ecosystem)
-FR945 broadcasting HR via BT to iPad. It is also listening to the HRM via ANT+ because I use that for running.
-Zwift on iPad connected to Kickr for Control and to FR945 for HR via Bluetooth
My findings: The FR945 seems to broadcast the HR-Data from the HRM-Run. If no HRM is used but oHR, it will show the HR data in broadcast mode. If you use a HRM via ANT+, the watch will only show "--" and that it is broadcasting to another device via bt, but no numbers. In Zwift, there was 1:1 the same HR numbers like on the Edge.
Was that documented somewhere? I think its a cool change of behavior because usually HRMs are more accurate and less prone to errors than oHR. Mine not, its dissolving because of a lot of sweat over the years :-D
