Hello,
I like to tests new firmware and if I loose my old PR it's not a big deal.
Is there a way to keep them when installing beta firmware ?
Thanks.
Hello,
Thanks.
Thanks, it certainly obvious when you know where to look, but I don't find it.
The only thing I found is going to "Activities" then for example "Running", then "View Personal Records" where I accepted all PR.
And from here I don't find any "Send to device".
I can't even found a "Personal Records" section.
Thank you very much.
Are you looking in the mobile app or on the garmin connect website? I don't use the mobile app, so can't help you there, but when you log in to the website, there's "Personal Records" on the left-side panel, and ther you'll find a large "Send to device" button.
The personal records could be a bit tricky to find in the app.
Open menu->Activities. Click steps, running, cycling or swimming. There you can click "View personal records".
There is no send to device button in the app so you will have to go to the web page: https://connect.garmin.com/modern/personal-records
There is only Send to device buttons for running, cycling and swimming.
You will probably have to sync those via Garmin Express.
Tremendous, thank you very much !!!
