transferring settings and my activities from one 945 to another
Specifically the setup of the different sport activites and their screen setups
  • Yes. Open your GARMIN Folder copy Setting.fit and the contents of the Sport folders into NEWFILES (or something like that) then disconnect. There are several posts that describe this in more detail.
  • Okay, it has been two years since you asked, but I ended up here with the same question. This page on Garmin's website explains (https://support.garmin.com/en-US/?faq=AXV7LuWgc73v21nq6nbDa6) says the following:
    • Courses - contains courses.fit files that are your saved courses on the device
    • Locations - contains Locations.fit file that stores saved location(s)
    • Records - contains Records.fit file that stores personal records you have achieved
    • Settings – contains Settings.fit file which stores user profile, device settings and bike profiles
    • Sports – contains each activity profile as a separate file. Each file will include all settings for each profile, i.e. data fields, alerts, and layouts.
    • Totals – contains Totals.fit file which stores device totals for time and distance
    • Weight - contains Weight.fit files obtained from a Tanita platform
