With Beta 4.87 third party datafields are not visible/usable
I use DR6c1 Datarun and Stryd Runpower, Stryd Zones
I installed Beta 4.87 and the the page where datarun shows up was automatically removed after the upgrade to this Beta in my "Run"-Profile.
If i add the datarun datafield again, I can select it, but only "Timer" ist displayed in this position. Same with "Stryd Runpower"
I finished a run and Stryd has added all his data to the fit-File. Wondering that it seems to be active, but not showing up as datafield.
  • i haven't a prob with my Stryd Datafield, everything is working fine in this Beta for me
  • Had the very same problem. Just replace Timer field with Stryd field.
  • Ich hab es jetzt irgendwie geschafft. Nachdem ich "Laufen" auf Werkseinstellungen zurückgesetzt hatte, konnte ich das dr6c1 wieder hinzufügen und es wurde auch als dr6c1 angezeigt. Nachdem ich das Stryd hinzugefügt hatte, wurde dort aber wieder nur der Timer angezeigt. Nachdem ich nun eine Kartenanzeige eingefügt hatte, konnte ich auch den Timer auf Stryd ändern und Stryd wird nun ebenfalls angezeigt. Sehr komisch das ganze, aber es geht nun wieder.
  • Sorry, same in English: I've somehow made it now. After resetting "running" to factory settings, I was able to add the dr6c1 back and it showed up as dr6c1 too. After I added the Stryd, only the timer was shown there again. Now that I had inserted a map display, I could also change the timer to Stryd and Stryd is now also displayed. The whole thing is very strange, but it works again.
  • i forgot, that i run with Drews Interval App and Stryd, there i haven't to config any datafield, because the developer made this perfect, so i looked in the Garmin Running App and surprise, the Stryd Datafield and Estimated Body Temp Datafield was replaced with a timer field, so i re-added them gain and everything looks fine
  • I’m having the same issue with a couple of data field apps , they install fine but don’t show up in the data field , just the timer
  • I'm seeing this bug also. I just received a Stryd today - trying to add the connectIQ data field for Stryd changes to a Timer field. I eventually got it to stick but this should not be the correct behaviour
  • After the update to 5.00, all Connect-IQ fields have become timers again. Unfortunately, the same bug still seems to be there.
    I was able to add dr6c1 to the activity again after a factory reset and it is also displayed correctly, but when I add "Stryd Zones" or "Run Power" it is always only displayed as a timer. So far I haven't found a solution to reactivate the "Stryd Zones". Has anyone found a solution?
  • I found out something:
    If I remove my Connect-IQ field with dr6c1 I can easily add the "Stryd-Power" field and it will display correctly. Then, however, only the timer is displayed when adding dr6c1.
    Apparently only ONE Connect-IQ field can be used since firmware beta 4.87. If you try to add a second one, it will be shown as a timer.
  • I have now managed to fill both Connect-IQ fields again without the timer appearing.
    The following procedure worked for me with dr6c1 and stryd:
    Add the stryd field (will display correctly)
    Add the dr6c1 field (will appear as a timer)
    Now go to the first (stryd) correctly displayed Connect-IQ field and change the content to the other (dr6c1). Then go to the timer field and change the content to the stryd.
    Everything is displayed correctly.
