Altitude acclimazation not working
Hi!
Im shure That it was working last year in the week of climbing and hiking in the Alps. This year, nothing is happening. I track most activities as hiking, but also climbing is triggering nothing.
I can see heat acclimazation in the training status widget
Also, all day SpO2 is on. Im on SW4.41.
Is it working for you?
  • for me it works fine in 4.40 and now in Beta 4.87 and on Edge 830 on 5.50 & 5.66 Beta , you exchanged your mobile phone in the meanwhile?
  • No, im still on iOS. Even the same device.
    Why should a phone have any impact? Its a FirstBeat on device calculation.
    Missed the opportunity today to try a running activity (while Hiking/Climbing :-D )
  • Installing the newest beta made it reappear, even with the data from last week (i returned this evening to my home at 100m above sea level after a week in the Alps).
  • Sorry, i mistook it with Heat acclimazation, where the weather information on your mobile phone have to be correct!
    Anyway your Altidude on the watch is correct?
    i found something interesting, because during my runs i always got a wrong altidude, so i changed something on the watch setup.
    In Sensor Menu under Altidude you can set the calibration and there i use since a while DHM instead of GPS and i set to check before every activity the altidude before starting the activity himself, hope this helps, it works great for me?
    i am not sure, but i think you are a german guy, here i found a how to do:
    https://support.garmin.com/de-AT/?faq=Gl2juBbnSc1NJ36gkA9hS8&productID=633625&tab=topics
    0 Former Member in reply to f|33tStA
    Altitude calibration through DEM depends on how accurate of your GPS location. If GPS location is off, DEM will give you different altitude.
    I tried altitude Auto Cal continuously during activity but the result was not good since 945 new Sony GPS chipset is not good enough in tall trees hiking trail.
  • i had the same bad experience with auto Cal continuously during activity, my runs where up to 100m over my real altidude, since i changed it to the described settings, my altidude is more then correct, anyway for my feeling, the GPS search takes a little bit longer before i start my run, often arround 1min, but no prob, when altidude is OK then
  • Altitude was correct and automatic altitude correction is working, only acclimazation was noch working with 4.41 for me. (The thing wich is the Same like Heat acclimazation, but for altitude)
  • thats the thing, i am not sure, but it have something todo with your weather information on you mobile phone too, but i am not 100% sure
