Forerunner 945 Beta 4.87 now available
Download
Notes:
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 4.40 to 4.87:
  • Added support for FE-C and Smart Trainer control. See options in Bike Indoor activity.
  • Added support for workout videos. The video files can be downloaded via Garmin Express or over WiFi. These videos will display when using an MSN workout that supports them. Download MSN workouts through Garmin Connect.
  • Added support for displaying courses to viewers of the user's LiveTrack sessions. Various other LiveTrack improvements
  • Added in-place editing of data fields
  • Added additional options to Live Event Sharing. Triggers added for Every Mile and Transitions (allowing for multi-sport use)
  • Numerous improvements to music experience, usability, and WiFi
  • Improved Incoming Call handling
  • Fixed problem with device spinning/freezing on activity save due to unintentional file build-up. Note: device will need to sync to Garmin Connect after software update to resolve this issue.
  • Fixed problem where certain user's maps took an excessive amount of time to load on boot and were generally sluggish in use
  • Greatly improved Around Me search times
  • Updated numerous widgets to improve usability and look
  • Fixed inability of device to record longest swim PR
  • Moved Recovery HR to option on save/discard screen
  • Updated post-activity summary pages
  • Improvements to segments handling
  • Improvements/fixes for on-device weather. Fix instances of missing data.
  • Improvements to phone connectivity
  • Fixed HRV stress page layout
  • Fixed a few issues with Virtual Running and workouts
  • Various other improvements and bug fixes
Installation Instructions
  1. Connect your Forerunner 945 to your computer using the USB cable.
  2. Download and unzip Forerunner945_487Beta.zip. Place the GUPDATE.GCD file in the \GARMIN folder of your device's internal storage drive.
  3. From the RemoteSW folder in the unzipped download, copy the GUP3114.GCD into the \GARMIN\RemoteSW folder on your device.
  4. Disconnect your device from the computer, approve the update on the watch, and wait for the update to finish.
  5. If you would like to revert to the last public release software, place the GUPDATE-440.GCD file in the \GARMIN folder. Rename GUPDATE-440.GCD to GUPDATE.GCD before disconnecting your device. NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
  6. To downgrade your peripheral software, place the GUP3114-401.GCD from the RemoteSW\Downgrades folder into your device's \GARMIN\RemoteSW folder.
  • i want to use them!
    Then just download ready made workout and be happy. I don't understand your problem, sorry.
    There are instructions on Garmin's blog's, there's instructions on Fenix manuals..
  • Yes, there are instructions on how to download complete trainings, which contain, for example, 10 or 5 or 7 different workouts, but where I can't do the half of them, because of health problems or because I haven't special equipment.
    for example, i want to create my own Training with for example following workouts:
    Deadlift
    Back Squat
    Bench Press
    Barbell Row
    Pull/Chin-ups
    Military Press
    But where do i know, if for this workouts a Video is available?
  • Creating workout having those. Sync it to the watch. Go to Strength, select "Free" at first, then select Training -> My Workouts, and your workout. Then it has option to select "view"  Then if it has video, the start button has small video symbol and you can press start to play it.
    And if you already know what you can do and not, then I would guess you already know the movements and don't even need the videos.
    What I would like is that the videos would be on the GCW, so that when creating workout you could see what everything is before syncing to watch. The MSN Workouts has Instructions button when viewed on GCW, but my own creation does not, even if the watch has videos for my own creation. And when creating there's just textual list of the movements, no ability to watch the video on that phase.
    on the watch or in GCW (Garmin Connect Web), i didn't find a "Free" Option?
    not really, thats my prob, with a video i can easier decide, if i can handle it with my damaged shoulder or not
    yes, i think i want exactly the same, could be, that my english isn't the best to explain
  • on the watch or in GCW (Garmin Connect Web), i didn't find a "Free" Option?
    On the watch. But if you haven't synced any trainings there's no that option when you select Strength. It comes after you have trainings, it asks if you want to do one of them directly... And I remembered that it selected it straight away. It doesn't, you can select your own training from that and then do the "View" part.
  • now i found something out, it's impossible to send trainings to the watch, i got always following message on the watch:
    Exceeded maximum number of workouts. Some workouts not imported
    Totally strange, i deleted everything in Garmin Connect under my Training before!
  • Well, no idea on that. This was the first time I tried non-running workouts and it worked just fine for me..
    But if you deleted from Garmin Connect, isn't the problem on the watch side? Delete the workouts from watch? But if there's already none then ¯\_(ツ)_/¯.
  • you have to delete it on your watch ... not in connect
  • I just found how to install animated workout videos
    https://youtu.be/GWbWWlrFAWs
  • Another change; I raced a previous activity and with the beta it noticed when I returned to the start/end point and also told me that I had won by 2:45 with a little trophy. Having done this before, it was new for me!
