Screen burn-in
Seems the watch face that's displayed 22-23 hours a day is causing an image burn-in, as can be clearly seen with the backlight on.
Does anyone else have this?
  • That's not good at all. I've had mine with the standard stock watch face for just over a year now with no problem. Are you still under warranty?
  • Thanks . I also use one of the standard analog watch faces. I've had the device for almost a year now so it should still be under warranty. I'll contact Garmin but before I do I wanted to know if it's a single device defect or something more wide spread.
    Nobody else experiencing this? In order to see it I had to navigate to somewhere with enough unused screen areas around the edges (like the middle button menu + one click down) and put the backlight on.
  • I have this too. For me is the the watch face steps on the left that show the most, as well as the heart on the right.
