I’ve tried holding MODE+PowerON and only PowerOn etc, but the watch won’t start nor charge... is there anything else I can do?
If you're not able to charge it, then likely it is 100% depleted. First step would be to get it charged. As mentioned, clean the contacts. I used a pencil eraser on mine and that seemed to do the trick. If you can, swap the charging clip with a known working clip and charge with a known working power source. The device could be as old as 9 years old (released in 2011), so It's possible that the battery has reached its end-of-life, as Ii-ion batteries can only last so many charging cycles (~500).
