I hv a new FR945 and also still hv my old Vivoactive. Can they both be paired/synced and allow me to use either and the workout data be added to my connect databank?
You will see your activities in Garmin Connect regardless which of the devices you used during the workout. And both can be paired to your smartphone. One of them should be set to your preferred tracker though. And note that the data that comes from device A is not transferred to device B, with some exceptions.
Turn on physio true-up on both and data is shared between the devices, so if you do an activity on one, it shows in the history of the other, and data from the 1st is used by the 2nd. On the va3 it's under Settings>system and on the 945 under settings>physiological metrics. You can also turn it on for watches with GCM
