hello all. I am using forerunner 945 and edge 830. when i head over to garmin connect and i look at training status/load focus, the numbers that I get so not sync. is it because garmin connect does not look at both the 945 and 830 together?
From the photo, you can see that the numbers are different for the two devices. do i interpret it as
1. garmin connect does not look at both devices together. the numbers given are for the activities recorded using the respective devices
2. the numbers are similar/not too far off - so it’s a time lag somewhere between the devices
Thanks for any help in advance!
