The optical heart rate sensor and accelerometer appear to have stopped working on my Forerunner. If I perform a soft reset on the watch, the optical heart rate will start working again but it stops within an hour. I can tell from the heart rate graph in the Garmin Connect app that it's cutting out. It definitely isn't just failing to read – I can look at the watch on my wrist and the green light does not illuminate. It also isn't tracking steps throughout the day. And when I record a run, neither heart rate monitor nor cadence are recorded.
I recently updated my watch, the Firmware version is 4.00 (17bdab6) – I've also installed the most recent Sensor Hub update. If I connect an ANT+ sensor, I am able to get heart rate readings. I don't have any widgets installed on the watch. Has anyone else had this issue and know of a solution?
Thanks!
Kyle
