New to 945 after years of 920xt use. 2 questions
Where is the temperature gauge located that records temps?
Where do I see the actual battery charge percentage?  i.e. battery is 44% full.
Thanks!
  • Garmin has a temperature widget that doesn't come pre-installed and you have to add it if you want it. The only way to display battery percentage is to add it under "data" on the standard watch face, or download a CIQ widget.
    0 Former Member over 5 years ago
    Press the UP button until the MAIN menu appears and the battery percentage will be shown in the top portion of the screen.
