Hello,
I am trying to use Spotify on my FR945 version 4.0, so I updated to the last version. However, everytime that I try to download playlist I have this issue. Can it be fixed?
Thanks!
Hello,
Thanks!
I fixed the issue with my tactix delta after having the same problem. It's just a matter of changing the security on your network to WEP 128, and since then my Garmin can connect to dedicated 2.4 network, i have the other band 5g separate and the watch will not even pick it up as network. So change the setting and you solved the problem.
