Is it so hard to fix the sleep tracking?
Compared to Body Energy and Stress Level, it is clearly seen when i fall asleep and when wakes up,
Please merge this 2 data fields with sleep tracking, and start giving to people the accurate values.
Not sure how hard it is, definetly it does not seem to be a big priority for garmin, almost everybody that does sleep tracking does it better. Fitbit is often quoted to be clearly better, and the oura…
My Fitbit Charge HR, 4 years ago, flawlessly tracked sleep including 15 min naps.
Garmin's sleep tracking is by far the worst.
for one thing garmin cannot track naps, or any really any sleep outside of the pre-specified sleeping window.
Not sure how hard it is, definetly it does not seem to be a big priority for garmin, almost everybody that does sleep tracking does it better. Fitbit is often quoted to be clearly better, and the oura ring is praised to be the best for sleep analysis from what I read :).
It's working great for me. Records when I go to sleep, if I wake up in the middle of the night and when I get up in the morning. I see no difference when I compare Garmin's data with the Fitbit I use to own. Maybe the fit, size or weight difference between your Garmin and Fitbit makes one move around more than the other and that's difference?
Nor can Garmin, Fitbit, Apple, or any other watch track REM. In order to be in a state of REM, you must have rapid eye movement and increased brain activity. None of this watches are capable of detecting that. Their recorded levels are based merely on what stage the average person would normally be in based on clinical studies. Ever individual is different and their are too many factors such as medication, alcohol consumption, etc. to be an accurate prediction. These sleep tracking numbers are all estimations and should be taken with a grain of salt.
I think you missed the point. What was mostly criticized was that they get the sleep time totally wrong even if they have good data for it.
On the topic I've noticed that I might have the right time when I went to sleep and woke up, but then there is some server side handling and then the times are wrong.
This can be seen like, after sleep open garmin connect.. look at the sleep data.. then Garmin Connect syncs... and look again the sleep time, there is 1-2h more sleep. It was more spot on before this. I don't know what the crap they do on the server side, but they should stop messing with the time.
