HRM TRI or HRM SWIM chest strap vs wrist OHR
If I buy the FR945 do I still need the HRM TRI or HRM SWIM chest strap? Does the wrist OHR do the same job?
  • Really  depends on the sport you are trying to do.
    In general OHR is not as accurate as a chest strap and will never be. It is just slower to pick up changes for the heartrate. So in general you could say:
    - for activities where HR is not changing much and more or less consistent and not "jumping around" (interval training for example) you will get good  results
    - for really hard acitivities or interval training where you peak your HR and it changes a lot, the sensor is just slower and will not really pick up the changes in time, so a chest strap would get you way better results
    - weightlifting will also be difficult, because the moment of effort is quite short. Again the sensor will just be to slow and will not pick up much of a change or a change at all while benchpressing or something like that (but HR for weightlifting is not really important for me, so does not bother me at all)
    I for myself switch a lot.
    Normal running with same pace and quite low effort => OHR (i made tests and the Data for OHR and the strap are really close)
    Heavy intervall training  => chest strap
    race => chest strap, because of the "peak" in HR Data and it will be just more accurate
    for other sports it more or less really depends on what you are doing, i would say use the same logic: more or less steady effort => OHR will do the job   mixing effort => chest strap will do better (especially the shorter or heavier the effort gets).
    This is just the general function, on top of that there are some people which just do not have any luck with OHR data at all.... Don´t really know why, but i heard that skin colour, hairs and such can really confuse the sensor and result in bad HR reading. So i guess you COULD have the problem to be one of these unlucky people. But in general i would say "my logic" from above is quite accurate, just make sure that your watch can not move on the wrist and is quite tight. The less movement the sensor will have on the skin, the better the results.
    Swimming with the wrist heart rate enabled can be challenging. The large arm motions can affect the level of blood volume in the wrist area, chilly water can reduce the amount of blood in the tissue on the back of the wrist, and the water can “pull” on the watch creating a gap between the optical heart rate sensor and the skin.
    For best heart rate accuracy during swimming, use the HRM-Tri or HRM-Swim.
  • OHR has got heaps better since the first iteration. Most of the time when I've compared it with a chest strap it's fine but every now and then throws a wobbly. Even swimming it's pretty good. Problem is that it's not consistent if you want to reliably measure heart rate. For that to happen you need a chest strap that measures the electrical signal of the heart beat.
    In short, OHR is pretty good for 24/7 tracking but so-so for 'active' activities.
  • If you run, things like Advanced running Dynamics can only be usuable via the HRM-TRI/Run. You cannot get those via ohr.
    As for getting the job done, any wrist based ohrm is going to lag behind a chest strap at activities with higher heart rates as well as any activity that involves a modicum of muscle flexion. Ohr is fine for 24/7tracking, tracked walks, very light runs (like Z1/Z2) and maybe swimming? Can't really speak for it as I hasn't used it for such and they just recently enabled that.
    For reference:
    Chest strap: reads actual heartbeats in real time (primary source)
    Optical Heart Rate: reads blood flow in under the skin via shining a green light (sometimes defused with yellow. Garmin does not do this). Tertiary source as it is not counting actual heart rate beats, nor is a reading pulse (a secondary source).
    While Garmin's Elevate OHR is better than it was when it came out (on the Forerunner 235) there are still a lot of factors that make OHR subpar for accuracy. If you're not going for near beat for beat, sure it'll work, but the info you're getting can be drastically off (HIIT with a ton of wrist movements for example). Expect heart rate reports anywhere between 60-100 BPM lower than actual, due to so much obstuction.
    I'd make the investment in the strap. Even if you don't run or don't care about the advanced metrics you could pick up the HRM-Dual. It's cheaper, can use it BTS or Ant +, pod based so you can wash the strap seperate, or use it with a completely different strap.
