Hello ,
just had the 945 restarted during the run leg of an olympic tri - about 2h:10 into the activity. I suppose this is a known issue at Garmin or would you guys need some logs from my device? I'm writing you here as most probably the regular support will advice me to do a hard reset :D :D :D
Regards,
Tudor
LE: I just noticed that neither the Running Power is not computed for the run part nor the Performance condition - and there was also a HRM disconnect; the HRM is a HRM tri that works otherwise fine, so there is definitely an issue. You can find the activity here - https://connect.garmin.com/modern/activity/4080944129
