Hi,
I’ve used the Stryd IQ power field in the past, and plan to continue using it (for leg stiffness, etc.).
I have recently come across Run Power, which displays many power related metrics like NI, etc. So I plan to use this to monitor my NI while adjusting my running technique.
The Run Power IQ app allows you to save the power data to the FIT file. However, if I keep the both the Stryd IQ power field AND the Run Power app running, I would assume I don’t need to enable the Run Power logging of power to the FIT file because it’s already logged by the Stryd IQ power field.
Has anybody used both in parallel, and can confirm that there power data from Run Power would be à duplicate of that from Stryd (or à duplicate, minus leg stiffness, etc.) ?
Thanks !
