Creating a course - with way-points for "ETA NEXT" - using Garmin Connect?
've read through related posts and can't quite find a simple answer
This is what I'd like to do:
  • create a course to run,
  • with waypoints [e.g. water stop] -
  • and have my garmin's datafields for "ETA NEXT" to refer to the waypoints that I have created.
The problem I'm seeing
  • I can create a course easily with Garmin Connect. [I can also import gpx files fine]
  • I add "Course points" for water.
  • when i start the run, my data fields for "ETA NEXT" and "ETE NEXT" only refer to the finish point. not the course points I added
I've seen mention of Explore.garmin.com, which allows addition of "way points". But the process looks very convoluted when GarminConnect appears to do exactly what I want [albeit not working]
Any clues? I'm a total newb at the forerunner - bought it this week
thank you
