Because of my very low synchronization speed to Garmin Connect App I tested, if my watch is really synchronizing with WIFI.
I disabled my Bluetooth connection on my phone and forced my watch to perform the synchronization (press longer the Light Button and select synchronization).
1. Wach search a WLAN network.
2. After ~50 seconds I get the feedback that that no connection to the network possible. Error code 500.
→ That explain my very slow synchronization!
On the other side I had installed the WLAN correctly.
When I go in GC on my device → General → WLAN Networks → Choose my WLAN.
Then I start the network test. The App & the watch itself report “successfully connected”
I can also see on my router that the Forerunner is connected to my router with the name “WILC”.
→ But after disabling Bluetooth same problem: Error code 500.
I turned on my watch the power on and off.
I made an actualization of the WLAN password on the watch (hard to type, but finally successfully) and with the Garmin Connect App..
I disconnected and reconnected my WLAN Network on the whatch and in the App.
I changed the WIFI Password on my router to a short one with numbers only.
I changed the WLAN router to operate 2.4 GHz only (took 5GHz away).
→ No success. Still no sync with WIFI, but Error code 500.
I read that only 2.4GHz channels till 10 are supported. So I set my router to different channels and deactivated full speed (600Mbit/s)
→ No success, but I got a different messages after changing of router settings: “Wrong Password”.
I used my Samsung S8+ smartphone as a WLAN access point instead of my router.
→ It worked!
It seems that the Forerunner 945 has a problem with my Telekom “Speedport Smart 3” Router. Newest model from “Deutsche Telecom” since ~1 year.
In total I have set up today >30 times the WLAN connection of my Forerunner 945 with different router settings.
The installation worked always well.
The network test with activated Bluetooth worked well. The App & the watch itself report “successfully connected”. But finaly the WLAN Syncronisation ended up with Error code 500.
I see that in the Fenix 5 Plus Forum they have also discuss this problem, but no solution:
PS: I have a German version of the watch, therefore my translation for the menus or errors is maybe not 100% correct for the english menu.
Any hints, how to solve the problem?
It seems that the Garmin Forerunner 945 has some WLAN restrictions which are not mentioned anywhere.
