Does anyone know where the excercise load data are stored in the fit file? It doesn't seem to be easily located when converting to CSV. I've posted elsewhere on this forum but hoping footfall is higher here. Thanks.
also asked here exercise-load-in-fit-file
how did you make the csv file ?
upload your fit file here fit2tcx.runalyze.com you can post the link you get from the upload here in the forum
or
do you consent in uploading the fit & csv file here or provide a link to it on a cloud storage
so we can have a try at finding the exercise load
happy searching
Here is one where the exercise load is 74: fit2tcx.runalyze.com/.../593733ad9ac665f66f42a848929c4428.txt
I used FitToCSV.bat from the ANT SDK to make a CSV
Here is another one where the exercise load is 164: fit2tcx.runalyze.com/.../8da104a39ad02af0b80807c1f7304985.txt
I have attached the top fit file. It won't let me attach the CSV.
It won't let me attach the fit file or csv. Here is a link https://1drv.ms/u/s!Atx8lntMOSfZj4kiWPIjNNc2C3huoA?e=hzX2WT
I can't see Exercise Load anywhere.
Oh thank you! How did you find those numbers? It reports the training load on my watch and I can have a data field that is called load - I'll check if it is the same number but I was suspicious it was calculated on the watch... Could it be that the Ant sdk isn't updated yet and it is in the fit file but not read by the sdk, but it's read by Garmin connect?
[Edit: I've just done a ride to check and it calculates it on the watch as I ride]
the numbers above are from Garmin Connect after uploading your fit files in my account
the SDK exports every value in the fit file (unknown labeled as unknown)
the value you see, while in an activity has not to be the value written in the fit file
could be a formula with tss and ...
happy searching
a wild rough guess...again
factor between 164 / 74 = 2,2162
suppose the exercise load is one value stored in the fit file
search the files for an equal factor between unknown values as the above one
vvvvvvvvvvvvvvvvvvvvvv
(164)--- xxx168=10776324=10776324
(74) --- xxx168=4855722=4855722
factor between 10776324 / 4855722 = 2,2193
factor between values from the above post (data from Garmin Connect activities)
164.43365478515625 / 74.09243774414062 = 2,2193
constant for 10776324 / 164 = 65709,2926
constant for 4855722 / 74 = 65617,8648
check another file to verify the wild rough guess
--- xxx168=xxxxxx / 65663,5787 = ??????
happy searching
Also, one last question please - how did you get som many decimal places here: 164.43365478515625
and here 74.09243774414062?
Using those precise numbers I get:
10776324/164.43365478515625 = 65536
4855722/74.09243774414062 = 65536
So the value in --- xxx168= should be divided by 65536 and that is the training load. Amazing!
