Hello everyone, I would like your help, if anyone knows, for the following problem I have with the forerunner 945's Wi-Fi. In particular, it sends my activities to my router only manually and not with the automatic process. This is the case lately, and it was initially working normally. If there was a problem with running the wifi on fr945 then it would not work manually. Also, I'm not sure if the problem arose after the latest software update and it's probably a bug that can be corrected in the next update. Thank you.
