Does anyone have the Jabra elite active 65t ?
Could you manage to get them to work with the 945 ?
I was able to connect them after trying 100 times but the watch never finds them afterward
Yes, i have the 945 and the elite active 65T.
I had some troubles but now it works.
Remove the Jabras from the 945.
Pair them as headphones but DO NOT add them as running sensors (it will keep asking once in a while).
Occassionally i have still issues connecting them but most of the time it works.
Thank you, I added them as a sensor indeed. Will try to remove them.
For those still having trouble with this, the key for me was making sure I disable BT on my phone before turning on the JB Elites. Otherwise, the headphones will connect to the phone and not the watch. So the steps I use are as follows (and it works every time):
1. Disable BT on the phone
2. On the watch go to Sensors & Accessories and select the Jabra Elite 65t. It'll starting looking for a connection.
3. Turn on the JB Elites.
This works for me every time. I actually considered buying a cheap pair of BT headphones just for use with the watch until I finally figured this out.
