RE :Physio True Up EDGE 1030 ans Forerunner 945
Possessor of a GARMIN EDGE 1030 and newly a Forerunner 945, I also noticed that the training loads between these two devices did not synchronize. The scores and statuses are different from one device to another.
I made several bike trips with my EDGE 1030 and then I made the synchronizations between my two devices. Each time the scores and status did not coincide. So I tried to do the synchronizations by removing Physio True Up on both devices. I got two different results which makes sense. I then put the physio true up function back. there was a change of score for the Forerunner 945, but that is not the same as on the EDGE 1030. I noticed that the Forerunner 945 did not fully take into account the cycling activities which does not allow not actually have the same scores and status on each device. Maybe a future update on the Forerunner 945 will solve this problem.
  • for the moment I use the 945 and the 1030 to record the ride and just discard the ride on the edge at the end. A bit boring to be honest because it remembers me when true up wasn't there and I had to do that on my 935 ...
  • Same here. However there is another thread (physio True Up) discussing this. So it would be great if you could post on that thread to keep things tidy. I've also reached out to Garmin support pointing to that thread.
